New Beta Firmware 19 April 2016
U4 Quad Hybrid
19 Apr 2016, 08:11
New Beta Firmware.
Full Version(18 April 2016)
Clean all user files include channels and user apps.
https://drive.google.com/open?id=0B_dRT ... HpCSFc1R0E
Normal Version(18 April 2016)
Keep user DB file and User Apps.
https://drive.google.com/open?id=0B_dRT ... HA3SlNLcVU
Here is list what we fixed on this beta version.
1. Support Group List
All, Satellite, Favorite, Bouquet,FTA/HDTV channel list.
2. Support Detail channel Information UI.
3. Fixed DiSEqC 1.2, USALS movement issue when you select each satellites.
Hidden Menu(2,5,8,0)
1. Added myConstCW(BISS)/myXCAS(EMU) on/off menu.
2. Support more 8 Services
3. Fixed PowerVu Audio issue.
4. Support loading function of softcam.key from USB stick.
5. Support loading function of cccam.cfg from USB stick.
We will new link SW within a hour. Sorry.
dude-nl
19 Apr 2016, 08:23
Any news on the EPG problem (dvb-c scrambled channels only shows 2 events, FTA and sat show more).
Any news on E2 style channellist so you can see current program EPG in channellist view?
Digitaldan
19 Apr 2016, 15:14
Get error message when try to install. Trying to install the "save database" version over the last "beta" version. Am I missing something? Thanks.
19 Apr 2016, 15:55
dude-nl wrote:Any news on the EPG problem (dvb-c scrambled channels only shows 2 events, FTA and sat show more).
Dear Dudu.
We are sorry that we could not fix yet your request.
We will start to check your issue again. Due to support Group list, we changed lot of internal code. so we couldn't fix your other issues. at first, we will check EPG issue at first.
Change of E2 styple channel list, it will takes some times.. we should change a lot of codes for E2 style's channel list.
It is not simple to support because it is related with EPG parsing for other events..
19 Apr 2016, 15:56
Digitaldan wrote:Get error message when try to install. Trying to install the "save database" version over the last "beta" version. Am I missing something? Thanks.
Sorry, DigitalDan..
We can not clear what is your issue. please can you capture your message or takes a photo what message you have and put on this forum? then we will check your issue.
Digitaldan
19 Apr 2016, 16:19
Let me describe...
I load the update to USB. Put USB in box. Then go to the settings and then to System. Then select USB upgrade.
I get no problem to this point. Box asks for accept. I accept.
Box gives reboot message. Box reboots. Upon reboot I see the Android start to update.
Then Android image falls over backwards and I see "ERROR" for a second. Box reboots and loads old beta file
So imagine a "dead" Android with a red triangle and the word "ERROR" on update screen.
Have the last Beta firmware loaded on box for last few weeks.
Thank You.
UPDATE: Used a different USB and box just updated. Thanks again.
satman
19 Apr 2016, 16:45
satellite rename is not ok.I rename a sat Name but box not Change it! :?
fix the Forward button for YouTube! ist not work
satman
19 Apr 2016, 19:23
Tuner Information>>> Lock Status; wenn i look here see LOCK after a 1 secons Change to UNLOCK!
yore very profi Software maker :D
and this..
dvb Parameters on DVB-S2 not Show!! Image
Digitaldan
19 Apr 2016, 22:36
After running this version for about 4 hours, box went into boot loop. Box was way hot! After cooling down, reverted back to previous version firmware. This release seemed to really heat up the box. Thank you.
20 Apr 2016, 01:38
satman wrote:Tuner Information>>> Lock Status; wenn i look here see LOCK after a 1 secons Change to UNLOCK!
and this..
Please reboot to see parameters. it will come correctly.
