How to change Video Format.
Post by xbmc » Sat Feb 20, 2016 3:39 pm
1. How to change Video Format.
There are 2 way to change Video resolution output.
1). With STB Remote Control.
Resolution by U4 Quad Hybrid.
NTSC/PAL (Analog TV) : LED Display : PAL/ntSc
720P 50Hz : LED Display : 7205
720P 60Hz : LED Display : 7206
1080i 50Hz : LED Display : 10I5
1080i 60Hz : LED Display : 10I6
1080P 50Hz : LED Display : 10P5
1080P 60Hz : LED Display : 10P6
2160P 24Hz : LED Display : U324
2160P 25Hz : LED Display : U325
2160P 30Hz : LED Display : U330
Upto Supported TV resolution, U4 will support TV resolution till 4K30Fps.
2). On eOn UI, Setting ==> A/V 출력 ==> HDMI, Select your resolution..
2. Change OSD size
80% : 4:3 TV , 80% : 16:9 TV , 90% : 4:3 TV , 90% : 16:9 TV , 100 %, And User Define.
Return to “Manual”
