Disecq configuration option in UI
Bugs, Issue report.
Robbin2685
Post by Robbin2685 » Thu Jul 20, 2017 11:24 pm
Hi Admin & Developers,
I've been with U series receivers for quite sometime now. One of the major challenge that I've found a satisfactory answer is about selected satellite in tuner configuration menu.
In both U4 & U5, the menu looks same for satellite tuner configuration. So when I'm selecting Disecq version, after selecting the port number, i select the satellite that I want to scan. But no idea till date how to select satellites (in tuner menu, of course) which are connected on remaining ports of the same Disecq switch.
Would really appreciate if someone can share tutorial with screenshots and also if UI developers can make changes to menu to make it simple and easy to use like xcruiser has (just an example). N I'm talking about UI changes for both U4 & U5 here.
Re: Disecq configuration option in UI
Post by vivant » Thu Aug 03, 2017 6:03 pm
Thanks for your suggestion.
Unfortunately for now we will not make UI changes until Android 7 and E2 are done. And moreover, we are not very clear about the UI logic you mentioned. Can you post some pictures?
Return to “Reports”
