How to Root U5 PVR via Linux.
13 Jun 2017, 08:29
This time, let's look at how to simplify the routing with Linux firmware installed.
In case you have a server failure, you can also load the root files.
u5pvr-root_1.0.deb
Open u5pvr Linux shell.
root@u5pvr-debian:~# wget http://u5pvr.djjproject.com/u5pvr-root-android.deb
root@u5pvr-debian:~# dpkg -i u5pvr-root-android.deb
root@u5pvr-debian:~# reboot
Download -> Install -> Reboot That's it.
Was the routing good?
Well done.
Binary update is "normal" to do.
Done
12 Jul 2017, 15:18
after typing reboot I get this: Running in chroot, ignoring request.
12 Jul 2017, 15:25
DannyPTY wrote:
12 Jul 2017, 15:18
If you can't reboot, use below command /system/bin/reboot
Michu7
08 Nov 2017, 11:54
Yesterday I tried root according to this tutorial but i could not download given files from server.
Terminal just stuck on downloading phase.
Please fix issue and put this files to server one more time.
-- edit ---
Strange thing, now I can download this file via Chrome on my PC, but I cannot do this via Terminal from u5pvr.
After get to u5pvr.djjproject.com now I see that maybe my u5pvr didn't understand command because now I have AT7 onboard and I see that apropriate file has different name: u5pvr-root-android7.deb (I tried to download version without 7).
--- edit 2 ---
Success. Everything went well.
08 Nov 2017, 22:03
Michu7 wrote:
08 Nov 2017, 11:54
-- edit ---
--- edit 2 ---
Great Michu7
09 Nov 2017, 00:08
root coomands with AT7
- wget http://u5pvr.djjproject.com/u5pvr-root-android7.deb
- dpkg -i u5pvr-root-android7.deb
I just completed it too.
Regards
revolution887
22 Aug 2018, 10:31
Hello,
There is an error with the root u5 pvr, to see if you can help me
Code: Select all
u5pvr-root-android7.deb.1 100% [============================================ ==================================================================================================== ============================= 2.34M 144KB / s in 18s
2018-08-20 21:51:31 (137 KB / s) - 'u5pvr-root-android7.deb.1' saved [2451088/2451088]
root @ AOL-Debian: ~ # dpkg -i u5pvr-root-android7.deb
(Reading database ... 28674 files and directories currently installed.)
Preparing to unpack u5pvr-root-android7.deb ...
unable to connect to localhost: 5555
error: device not found
mount: can not remove rw read-write, is write-protected
dpkg: error processing file u5pvr-root-android7.deb (--install):
  subprocess new pre-installation script returned error exit status 32
Errors were encountered while processing:
